Sharp LC26GA4 or Toshiba 30WL46?
Discussion in 'LCD & LED LCD TVs Forum' started by tesh, Jan 16, 2005.
Tags:
  1. tesh
    tesh
    Jan 13, 2005
    42
    I am considering purchasing one of these two models to use mainly as a pc monitor. They are both around the same price and I was close to deciding on the Tosh but the Sharp seems to have a better resolution. Will this make much difference? Can anyone who uses either of these models with their pc's (via DVI connection) let me know what they think.
    Tesh
  2. gnudi
    gnudi
    Seems that the 30WL46 cant go higher than 1024x768 via DVI...
    Not absolutely confirmed (I'm still trying) but seems to be the sad truth :(
  3. PhilB1234
    PhilB1234
    I use the DVI connection on my 30WL46 to feed it 1280x768 (native resolution) images from my scaler, so can't see why a PC would have any issues. It works magnificently! I would highly recommend it! In my opinion the superior looks and larger screen size make the Tosh the one to go for from your shortlist.
    See empire direct for a price of around £985...
  4. gnudi
    gnudi
    Yes I know you got 1280x768 from your scaler but till now I havent seen anybody succeeding from a pc and since its going to be his main usage , he has to know that, dont you think...
    If it wasnt about pc well I choosed the Tosh myself ;)
  5. tesh
    tesh
    Jan 13, 2005
    42
    Thanks for your feedback guys, I was leaning towards the Tosh as it is the bigger screen and I know for a fact the tv picture will be superb. Is the picture in picture any good? as I think I will be on the pc most of the time and want to watch tv in the corner
