Sharp LC22sv2e LCD TV in our Bedroom - Picture Advice
Discussion in 'LCD & LED LCD TVs Forum' started by dunbad, Oct 11, 2004.
Tags:
  1. dunbad
    dunbad
    :lease: Hi
    I'm kinda new on this forum?
    I have just bought this LCD TV after reading all the excellent past reveiws on Home Cinema Choice etc.
    I bought it from Empiredirect.co.uk for £698.00 V Cheap I thought as a year ago it was £2500.00.
    I have mounted it to our bedroom wall on a Vogal EFW 1030 bracket which is superb.
    I have connected the RF2 out cable from the SKY+ box with a Triax magic eye.
    My only concern is the picture quality which is quite poor and RF2 only sends out Mono sound from the SKY+ box.
    I know idealy I need to connect the LCD to the SKY box via Scart utilising RGB. The problem there is that to get a scart lead to the LCD would mean me drilling quite a large hole to fit the plug through. So I would be pleased if anyone could give me any advice.
    By the way I have tried a Tevion wireless video sender but that was really poor.
    Look forward to your help.
  2. TheBoingoBandit
    TheBoingoBandit
    Jul 27, 2002
    779
    28
    +26
    What about using a S-Video+2phonos to S-Video+2phonos connection instead wich would require a smaller hole, give better picture quality than composite, RF or a video sender and free up both scart sockets on the Sky+ box?
  3. dunbad
    dunbad
    Thanks Boingobandit!!
    I have been on the phone to Sky today to try and get a good cheap deal on an extra Sky+ box for our bedroom.
    They want £149 for the box etc and £10 a month for the second subscription.
    A bit expensive just to acheive an RGB signal? Would S Video be much lesser quality than RGB scart. Baering in mind its an LCD in the bedroom. Also can you buy a cable with all the wires in one outer sheath as it will be outside in the elements.
    Again Thanks
  4. chunkymunky
    chunkymunky
  5. TheBoingoBandit
    TheBoingoBandit
    Jul 27, 2002
    779
    28
    +26
    The original Sky+ box can output S-Video to the bedroom. As I mentioned the plug will be a lot smaller.
    OK, the quality won't be quite as good as RGB scart but for a screen that small you won't see too much of a difference. I would advise not using ultra cheap cable though. The cable mentioned above would be sufficient.
  6. PeteCallaway
    PeteCallaway
    Jun 16, 2004
    9
    I was just wondering if you came up with a neat solution - I'm in the same boat as you ;)
    Cheers,
    Pete
