Sharp LC-37HV4U Speaker Problem
Discussion in 'LCD & LED LCD TVs' started by AlexNguyen, Jan 9, 2005.
  1. AlexNguyen
    AlexNguyen
    All the sudden my TV is not letting me select "internal speaker" option. The only choice I have is "external speaker".
    I am connecting the TV to my Digital Satellite using DVI. It was working fine for the last 6 months.
    Has anyone experienced this problem? I would really appreciate your help.
    Thanks.
  2. Sledge
    Sledge
    You may have turned on the option to habe your speakers work as the centre channel for a 5.1 system.
    Can't remember where that setting is but that could cause the option to be disabled.
