Just bought a Sharp LC-32GA5E (Thanks to this forum for the guidance on making my choice)
I have a Sony DVP-NS400D DVD and was wondering is someone can recommend optimal settings
All info I have found here seems to be on the Sharp Series "3" & "4"
I guess I should be focusing on a few areas here
Connectivity
Is SCART cable best? (no component outputs on my DVD)
I will upgrade this to a higher spec cable at the w/e
DVD Output
I have adjusted this to RGB - Is there any other options I should be looking at?
Sharp Input
EXT1 (RGB) - Set to RGB from Auto (just in case)
Using the "Standard" Picture levels at present - Should I adjust the Advances setting to get a better PQ
Haven't seen much difference yet - PQ is average (I assume the default SCART cable is the main quality issue)
Want to get this right before I start watching series 2&3 of "24"!!!
Connectivity
DVD Output
Sharp Input
