Sharp LC-26GA3E - HDTV support
Discussion in 'LCD & LED LCD TVs' started by Kelh, Feb 2, 2005.
  1. Kelh
    Kelh
    Hello,
    I'm sorry to ask this but I just couldn't find an answer to my questions when searching the forums.
    What I need to know before buying this TV is :
    -Is the DVI input HDCP compliant ?
    -Does it support 720p @ 50 hz ? If not, could it be a problem for future compatibility ?
    Thanks in advance
  2. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,026
    41
    dat london
    +13
    Hello !
    Yes
    Yes
    No Probs,
    Richie.
  3. MickyGee
    MickyGee
    Jan 6, 2005
    294
    Preston
    Many threads on this issue. You will find that the DVI input is HDCP and does support your resolution.
