Sharp GA4E screen resolution
Discussion in 'LCD & LED LCD TVs Forum' started by zap, Nov 30, 2004.
Tags:
  1. zap
    zap
    May 19, 2001
    282
    U.K.
    +3
    I manged to pick up a 32" GA4E today & have managed to have a little play with it tonight. But I am really struggling to get the pc to do any thing other than 856x480. I have installed powerstrip but I cannot get any other resolution to work.
    I am using a Radeon 9600 pro & using the DVI connector. I have read here that others have had 1360x768 working, but they do not say how they have managed this.
    Has anybody got any settings I can try?
    zap
  2. APC
    APC
    I used one of the presets in Powerstrip labelled '1360x768 (PDP)'. Also, make sure that:
    -dot-by-dot mode is selected on the input mode for the PC
    -you have also selected 'PC digital' (if using DVI).
    -you have specified 1368x766 as the input resolution on the TV
  3. zap
    zap
    May 19, 2001
    282
    U.K.
    +3
    Thanks for the help, unfortunately I have not had long to have a proper play. So far I have managed to now get it to go to 1280x720. I am yet to find the other settings on the tv you mention looking quickly through the menus. Hopefully I get more time tomorrow & set it up properly.
    zap
