Sharp GA4 automatically switches off??
Discussion in 'LCD & LED LCD TVs' started by cbemoore, Feb 10, 2005.
  1. cbemoore
    cbemoore
    May 16, 2002
    1,220
    38
    Eastleigh
    +16
    A friend of mine has a problem with their Sharp GA4E screen switching itself off automatically.
    The screen is a Sharp LC-37GA4E screen, with a sky box (attached via RGB scart to AV1) and a Denon 3805 amplifier (attached via component to AV3).
    For some reason, when viewing Sky on AV1, the screen automatically switches off after 5 or 10 minutes! Just before going blank, the screen displays "Amplifier" in red on the bottom right hand corner....
    So far I've checked that:
    - All the screen savers are definitely switched off
    - The sleep timer is definitely switched off
    - The problem only occurs with the Sky input. All other inputs are working fine
    - Sometimes, switching the amplifier off and back on again seems to fix the problem temporarily. But I haven't a clue why, because the amplifier is connected to a different input!
    Has anyone come across a problem like this before, or got any troubleshooting tips? I'm a bit worried the screen is knackered, but its strange that it only happens on the Sky input....
    Chris
  2. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,026
    41
    dat london
    +13
    Have you tried it with the Sky plugged in but the amplifier left out ?
  3. cbemoore
    cbemoore
    May 16, 2002
    1,220
    38
    Eastleigh
    +16
    Just tried with the amplifier switched off, and the problem still occurs....looks to me like the screen could be knackered! But its strange that never happens when watching terrestrial channels....
    Chris
  4. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,026
    41
    dat london
    +13
    Take out the Component cables completely and try again.
    If terestrial viewed through RF ?
  5. Daftboy
    Daftboy
    Jan 8, 2004
    505
    +12
    Have you tried calling Sharpserv incase it is a known fault?
  6. deadred
    deadred
    Nov 18, 2004
    2,569
    71
    Cumbria
    +96
    Screen savers???? Where are these?
  7. cbemoore
    cbemoore
    May 16, 2002
    1,220
    38
    Eastleigh
    +16
    Latest update:
    There's definitely a problem with the AV1 input. I tried connecting a DVD player to both AV1 (RGB scart) and AV5 (DVI). AV5 works fine, but AV1 cuts out after a couple of minutes. I've tried changing the scart cable and the problem still occurs.
    I've called the Sharp service dept, and I'm waiting for an engineer to call back....
    Cheers to everyone for your advice
    Chris
    PS - deadred - the screensavers are in the screen options menu....
  8. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,026
    41
    dat london
    +13
    Also try plugging the Scart into input 3, this is also an RGB input to make sure that it's the input and not some other kind of trickery further down the line.
