Sharp GA4/3s and using DVI for DVDs
Discussion in 'LCD & LED LCD TVs Forum' started by calvinhobbes, Dec 1, 2004.
Tags:
  1. calvinhobbes
    calvinhobbes
    Hi All
    Is there a way of using the DVI port on the Sharp TV for non-PC usage e.g. DVD? E.g. if the DVD player is non HDCP compliant, then will it work?
  2. jgrg
    jgrg
    Oct 19, 2004
    557
    28
    Cambridge
    +36
    Yes, The DVI port should work with both HDCP and non-HDCP (PC or DVD player) connections.
    James
