SHARP GA4 26 best settings ?
Discussion in 'LCD & LED LCD TVs Forum' started by naisy, Apr 2, 2005.
Tags:
  1. naisy
    naisy
    Sorry to post this again however i have just purchased one of these sets and are looking for advice on the best settings for the tv to get best picture ?
    I am connecting a Freeview box and a dvd player
    What leads should i use and what should i set the ratios at within the dvd player and freeview box re output ?
  2. gslater
    gslater
    Mar 18, 2005
    129
    London
    +3
    I have a 26" GA3 and also looking to get the best settings.
    I currently connect from my sky + box to the input 1 on the screen using a scart. The sound is connected seperately to an amp using an optical lead.
    My DVD is connected to the screen using S-Video lead onto input 3 on the screen and the sound is similarly connected to the amp using optical.
    My VCR is connected to the input 2 of the screen using a scart, with sound going to the amp using scart to component.
    This seems to work ok, but I still feel it is not optimal...when I saw the screen in the shop it had a much better picture and now it looks like it has some ghosting as well as looking a bit "cartoonish".
    Any thoughts?
    I was told to use a RGB scart to connect the sky + box to the screen...is this the same as a simple scart lead, or is there a special type of "RGB scart"?
  3. LcdGuru
    LcdGuru
    Most scart leads have the RGB lines connected. You need to select RGB output on the sky box and RGB input on the Sharp. Should produce a big improvement in picture quality over composite - in particular eliminating colour crawl.
    Re: setting recommendations - try doing a search on "GA4 settings". There was a long thread a couple of months ago. Optimum settings vary according to your source (which is OK since the Sharp automatically remembers your settings for each input).
  4. gslater
    gslater
    Mar 18, 2005
    129
    London
    +3
    Thanks....how do I select RGB output on the sky box...presumably there is something in the sky setup screen?
