Sharp GA3 RGB input 1
Discussion in 'LCD & LED LCD TVs' started by richjthorpe, Apr 15, 2005.
  1. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,026
    41
    dat london
    +13
    Hi All,
    Got my Sharp 32GA3 connected to a Digifusion FVRT100 Digibox via SCART to 'input 1' on the tv and 'TV out' on the Digibox.
    I was playing around with the settings last night (As you do) and started flicking between Composite and RGB on the Digibox but couldn't tell the difference in PQ.
    Anyone else had this with the Sharp ?
    Richie.
  2. MickyGee
    MickyGee
    Jan 6, 2005
    294
    Preston
    Does the Digibox Output RGB all the time Richie ? Try selecting the input at the TV end to see if the difference is more noticeable.
    P.S settings posted on sharp settings thread.
  3. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,213
    Glasgow, UK
    +1,310
    It's possible with a very good comb filter in your set, you might at first glance not notice the difference, especially if the screen clears itself in between switching between the two. Try turning the 3D Y/C option off (this is an available option on Sharp sets IIRC). You should notice a difference then.
