Sharp GA3 and GA4 will be replaced?
Discussion in 'LCD & LED LCD TVs Forum' started by stvn, Feb 2, 2005.
Tags:
  1. stvn
    stvn
    I have heard that the Sharp GA3 and GA4 series will be replaced soon for GA5.
    Is these true?.
    I cant understand why if both are similar in technical characteristics but GA5 have less connections and is more expensive.
  2. neilmcl
    neilmcl
    Oct 29, 2004
    6,236
    103
    Nottingham
    +292
    This subject's been covered quite a lot, Yes the GA3 has been discontinued in the UK and the GA4 is currently out of stock. Try searching the forum for further details.
  3. jimg
    jimg
    Jul 4, 2004
    826
    +58
    As Neilmcl has said there is plenty on the forum about this, the GA5 is not intended to replace anything; it is an entry level screen with lower functionality. The issue is around the 32" models and supply is practically non-existant of the GA3 and GA4 flavour.
