Sharp GA3/4E and DVI
Discussion in 'LCD & LED LCD TVs Forum' started by richjthorpe, Dec 1, 2004.
Tags:
  1. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    Has anyone linked up their GA3/4E to a DVD player with DVI out or HTPC ? Just want to make sure it is compatible with DVD players.
    Richie.
  2. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    I have connected an HDMI equipped DVD player up to a GD1E. I was unable to get 1080i to work and Sharp have admitted a problem with some digital sources - I would imagine the same issue exists with the GA models. Otherwise I was more than pleased with the results using 720p - up to then, it was the best that I had viewed.
    Always best to try try the source you intend to use with a display just to ensure no nasties present themselves.
    -Ian
