sharp bluray player and DIE HARD menus
sith1970
I bought the 3 die hard films on bluray this week and i found an odd behavior with the discs menus. They take an eternity to load and they are way too slow to react to remote control commands. The scene selections menu and the pop up menu option are just unbereable to use. All 3 discs have this problem, altough die hard 3 is not so severe. By the way, the Cast Away bluray also have this problem. Is the player at fault or is something to do with the discs themselves?
kingfats
Hi sith1970. :)
The Die Hard discs have been a problem for the Sharp,with it only being profile 1.0 and the discs Java based..............the player can struggle. :(
All the best.
sith1970
thanks for the info. i was suspecting the java sindrome was the cause of my problem. and i forgot the profile issue, as well.
Seems like a new player purchase is the only solution. Well, such is life...
kingfats
Hi sith1970. :)
Sorry about that mate :( there's been quite a few members who have complained about this boxset.
All the best.
Cabo 5150
I have a Sony S300 (now in the bedroom!) and a Panny BD-30. The Sony struggles as you describe to load my Die Hard discs and cope with the menus, while the profile 1.1 BD-30 is way quicker and a lot smoother with the menus.
AVForums Movies Podcast: We review Dune and ask which is the best decade for horror movies?
