SHARP Aquos Remote Control issues
andrewvmarin
I have a Sharp Aquos TV Model #LC-60EQ10U. The remote control is not responding so I did the following: replaced batteries, unplugged TV, upgraded TV firmware, and bought a new remote control. Nothing seems to be working and I can't get the remote and TV to connect. I'm looking for any possible solutions I may have overlooked. There appears to be no external damage to the TV and the Infrared "eye". This problem happened quite suddenly. Prior to this, the remote control worked great. BTW: the TV still works great.
JayCee
I downloaded and had a read of the user manual.
Read page “ENG 4-31” on “Operation Lock Out”
It's possible to disable the use of the remote control and the buttons on the TV.
If the remote control has been locked this section explains how to unlock it using the buttons on the TV.
andrewvmarin
Thanks for the suggestion. I followed the directions to disable Lock Out but unfortunately, the remote still doesn't work. Please let me know if you come across any more suggestions ;)
