Gibletts
Ok - could really do with some expert help here people.....
Have had my Aquos panel up and running for some time now.
I've got a 5 port HDMI switcher connecting the PS3, DVD (Sony DVP-NS76H), BT Vision Box & my HTPC. All using HDMI.
all running like clockwork...until last night.
I finished playing the PS3 and switched it off. Today I've lost the HDMI connectivity on the
PS3 & DVD?
I've tried all that reset stuff. Even reset it back to AV Scart (which works) and manually re-set the PS3 back to HDMI - All I get is a black screen with the 576 standard res in the top right.
The DVD player as well. It just flickers Black Scrren to "No Connection" Tried re-setting it manually (720p) Nothing!!!
Even stranger....
The HTPC works fine (720p @ 50Hz) No problem.
The BT Vision box (on-start-up) tells me - "Connection does not support HDMI" "Remove Lead and use AV" Yet there's a picture. When I set it to 720p the message goes away....
What's the deal....?
It cannot be the LCD? Can it? the HTPC works fine.
But what's the chances of the PS3 & DVD going boots-up at the same time....?
I'm totally lost here. Could the HDMI switch have stuffed my PS3 & DVD up?
Ended up having the switch the DVD & PS3 back to noddy AV connections. Booo! Rubbish.
Trawled the forums & I cannot see anything similar - and I re-set everything 10 times over.
HELP !!
PS3 & DVD?
Even stranger....
HELP !!
