Sharp Aquos LC-32P70E t.v wont retune?
DaveViborg
I have tuned in all the analogue channels(BBC1,BBC2,ITV,CH4,CH5) but when i press dtv it comes up with no service. So I go to dtv menu which shows an option for auto installation but when i press it nothing happens. The only thing that works is showing me what update is there 1.4. Anyone know how to tune the freeview channels in. By the way this has been happening before the retune today.
albani
Did you connect an DTV Aerial-antenna (indoor&outdoor) to your panels
RF port????
DaveViborg
I have an aerial attached but unsure what you mean about a dtv aerial. Its the aerial thats on the roof straight to the socket on the t.v.
Curly99
you may be in a bad signal area or the aerial you have may need changing, best bet is to get an installer to check the signal levels, your aerial etc you should be able to find an installer that will give you a free check/quote.
Curly
Daftboy
When you say nothing happens, do you mean that it just sits there or that it goes through the installation and finds no channels?
albani
Yes,you have to check signal level at first!
DTV works a different type of signal situation!
such as might be your location out-of-print for DTV reception!!
