T
thevoyeur
Hello all,
Just got my Aquos LC-32P50E on Friday and am having a bit of agro with the input options. Basically, I only really use Sky and a DVD player, so I've got them both connected to EXT3, DVD via Component and Sky via S-Video. I tried Sky on SCART, but the quality was a lot worse, so I just couldn't do it! Anyway, it seems to be a limitation of that input that in spite of it being set to auto detect the signal type, it doesn't actually switch the display between the 2 if you switch one off and other on.
Anyway, I've programmed my universal remote to go through the multiple key presses necessary to switch the signal types on EXT3 whenever I switch between Sky and DVD.... however, this isn't ideal.
Has anyone else had this issue? This is my first higher end TV... I've only ever had SCART inputs before... but it seems obvious to me that many people would want to use both S-Video and Component at the same time, yet it's a pain to have to manually switch the signal type.
Thoughts? Solutions?
