SHARP Aquos LC-32GA5E. Any good
Discussion in 'Plasma TVs Forum' started by Chip, May 10, 2005.
  1. Chip
    Chip
    Got chance of one of these at a very good price. Any good. Are speakers detachable.
    chip
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Underslung speaker is permanent, my advice, if you can get a GA4 with side speakers, it's a way better screen. They took off a HDCP DVI port to keep the price low for the GA5, not worth it.
  3. Sulis
    Sulis
    Mar 29, 2004
    577
    Bath
    And it's an LCD. Nuff said...
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    might be better off in the LCD forum with this question....
  5. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    The component inputs are HD and the pc input is HDCP DVI port compatible, in the user guide it shows how to connect this.
    i have my sony dvd connected via the rgb rca and i have to say the picture quality grabs you.Better than any old plasma :rotfl: .espcially as i am using gold plated oxy free cables and have it set to hd :clap:
    but it really does come down to signal....
    the best screen in the world would look poor with a bad analog RF signal compared to a low performance screen with a 100% digital signal
  6. captaindobie
    captaindobie
    Apr 17, 2002
    592
    Scotland
    +21
    Any good you ask?
    Well, in one word YES.
    Sure, it doesn't have the digital connection (and if this is important to you then fair enough, look elsewhere)
    However, if you are planning to connect DVD/SKY/FREEVIEW etc via RGB Scart or Component, then you will not be disappointed.
    If you can get this at a great price, (anything under £1000) then take the plunge. You will find many satisfied owners on these forums.
    If necessary, you can always upgrade in 3-5 years.
    (let's just see how HD actually takes off...)
    This screen is fabulous with a good quality signal (SKY/FREEVIEW) and exceptional with DVD.
  7. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    PS if you want a laymans terms YES IT IS FANTASTIC here it is. i have had mine for over a week now and still can not get over the clarity. have had quite a few friends round and they all comment it is very good.
    i purchased mine with a 7 day trial, and i will not be returning it thats for sure :hiya: :smashin: :thumbsup:
  8. scrapbook
    scrapbook
    Jan 12, 2002
    7,411
    +550
    Where did you get a 7 day trial from?
  9. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    I bought it from unbeatable, the shop is local to me and i visited the shop.
    i asked the manager and he made it an acception on. he made it very clear it was not usual, but i did get it for 1 penny short of £900 and that is the best price i have seen despite many searches.
    their web site is www.unbeatable.co.uk
    :smashin:
  10. jimg
    jimg
    Jul 4, 2004
    826
    +58
    Yep so it must be good! :rotfl: :rotfl:
