Sharp Aquos 45" LCD
Discussion in 'LCD & LED LCD TVs Forum' started by hornydragon, Aug 18, 2004.
Tags:
  1. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    OK guys just got details of the new sharp 45" screen!!!!!!!!!
    LCD 1920x1080 Res a true HD display!!!!!!!!!!!
    Will post other details when i can but someone out there must have listed them on their site!
    Cost????
    £7-7.5k :eek: :eek: :eek:
    Cant wait to see one!!!!!!
    Looks like HD is finally coming properly
    *************US model spec***************************
    Panel Type 45 Active Matrix (a-si TFT) Advanced Super View LCD1
    Pixel Resolution 1920 x 1080
    Video System NTSC
    Brightness 450 cd/m2
    Lamp Life 60,000 hours3
    Viewing Angles 170º H / 170º V
    Audio System 10W + 10W
    Tuner Type 8VSB/QAM/CableCARD™
    US model has HDMI and DVi so expect at least one in europe and i guess 2-3 scarts + hopefully component, i would guess a DVB tuner too.
  2. duncs
    duncs
  3. TheBoingoBandit
    TheBoingoBandit
    Jul 27, 2002
    779
    28
    +26
    It's already confirmed as DVI + component and yes, DVB is part of the tuner/switchbox.
  4. tradesman
    tradesman
    Aug 13, 2004
    107
    16
    Yep deffo off putting that price just been into my local Comet store to check out the diffrence in LCD & plasma was amazed at the wide selection they've
    even got a DLP rear projection there that blows your mind its getting harder all the time to decide whitch rout to go price is going to be the deciding factor for me in the end
    regards tradesman
  5. TheBoingoBandit
    TheBoingoBandit
    Jul 27, 2002
    779
    28
    +26
    That was most likely the Saegm which is currently running a high-definition demo at Comet.
  6. duncs
    duncs
    From the Swiss site (Babelfished)
    Pdf files
    Data sheet
    LC-45GD1E
    Technical data
    Visible screen diagonal 114 cm (45")
    Display format 16:9
    Brilliance 450 cd/m2
    Contrast relationship 800:1
    Dissolution 1920 x 1080
    Number of pixels 6'220'800
    Display Advanced super View Black TFT LCD panel
    Progressive Scan/digitally fixed image
    Viewing angle H:170°/W: 170°
    Actual working time of the background light (H) 60'000 h
    Display functions OPC (Optical Picture control), dual Picture, Picture and Picture, Picture and text
    EQUIPMENT
    Transmitter memory digital/similar 999/99 channels
    Transmitter assortment Automatic channel assortment
    Audio part 1-Bit digitally amplifier Dolby Virtual Surround, NICAM, A2-Stereo
    PC Card Slot function Image Viewer MPEG4 playback + admission
    Power output amplifier 2 x 10 Watts
    Teletext TOP/FLOF text
    Page memory 252
    Timer Switching off timer
    Safety device for children Transmitter-steered
    COLOR AND SOUND SYSTEM
    PAL PAL B/G, PAL D/K, PAL I
    SECAM SECAM L/L, SECAM B/G, SECAM D/K
    NT sports club rendition NTSC over AV/PAL50/60
    CONNECTIONS
    Antenna connection DIN/DVB t
    3 x Euroscart 21-poliger euro Scartanschluss
    Cinch connections AV/s-video entrance, AV exit digital audio exit
    Headphone 3.5 mm of mini socket
    Component entrance Y, Pb, Pr
    DVI entrance DVI i
    Further connections RS-232C
    Interface C.I. (Common interface) for Pay TV of programs
    GENERAL INFORMATION Mass (B x H x T)
    Dimensions with condition foot 1072 x 820 x 306 mm
    Dimensions without condition foot 1072 x 702 x 90 mm
    Dimension AVC system 432 x 95 x 303 mm
    Weight with condition foot 27 kg net
    Weight without condition foot 18,5 kg net
    Weight AVC system 7 kg net
    Voltage supply 220-240 V AC, 50 cycles per second
    Capacity at present. No indication
    Capacity (condition by) at present. No indication
    Price
    noncommittal price recommendation Fr. 14490.00
  7. 888
    888
    If you look at the Saegm set-up they're all connected to a PC to play the HD stuff. I'll be surprised if DVD or normal TV playback was anywhere as good. If it is it's an outstanding picture I must agree.
  8. calvinhobbes
    calvinhobbes
    The Sharp site specifically seems to exclude Europe as a territory for the 45". Does anyone actually know whether it is coming to Europe, and if so, when?
    The Toshiba 46" is a similar issue - only release details are for the US (it has v similar specs as the Sharp)
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    oh yeah baby saw the sharp rep today! its coming, no confirmed pricing yet tho £7-£7.5k is an estimate. could more could be less.
  10. duncs
    duncs
    See my post above from the Sharp Swiss site. Its definately not excluded from Europe.
  11. Rob20
    Rob20
    Jul 3, 2004
    3,107
    +665
    I can't see the point in spending £7,000 on a high def 1080p set when there isn't any hi-def material to take advantage of it yet. I'd rather wait til Blu-Ray's released or sky's hi-def service begins.
  12. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Euro 1080? D-theatre? Downloads via PC? Loads of HD content out there mate!
  13. calvinhobbes
    calvinhobbes
    Any estimated arrival dates for the UK / Europe?
  14. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    November to the uk, cant be more specific!
  15. Ultim8Fury
    Ultim8Fury
    sorry for dredging up old threads but I'm about to lay the cash down for one of these to replace my ageing Panasonic TX47pt-1 rear projection set. cheapest price I've found is £4987 iirc but they only sell to business. However ivojo have it at £5119 inc vat so I think its a done deal. Saw this set at the best of stuff/what hifi show and admittedly they were feeding it a poor quality low def signal from a japanese dvd player that they didn't have instructions for ( according to sales guy ) the picture still looked amazing. Will post back in the next couple of days when I've got it up and running.
  16. danvitale
    danvitale
    Nov 18, 2004
    2,340
    63
    By The Sea
    +114
  17. Ultim8Fury
    Ultim8Fury
    no not them. but good price though. I'm trying to get progressive AV to budge on the price they're offering cos they also have the DVD and amp I want. If not then I will be giving electrical world a ring.
    edit got a pretty good price from progressive and they seem very willing to help so they've got my business. Should all be with me on tuesday.
  18. 1ofaKind
    1ofaKind
    Dec 16, 2002
    233
    Midlands
    +4
    Let us know how you get on with it when it arrives - show us some piccys :thumbsup: you know you want to ;)
    I've been looking at all alternatives plasma/projector etc. but I have to say this set looks like it may have all the features I'm after, no burn worries (hopefully), HD, pc connection, its a tv so any one can use it easily :)
    Its expensive but heck so is a 50" plasma and it doesn't offer the same res.
    It has a seperate media box I assume? I've read some of the big threads over at avsforum about it where they have been doing all sorts with switcher boxes n stuff but reports have been good especially PC screenies.
    45" PC monitor hmmmmmmm drool! :devil:
  19. Ultim8Fury
    Ultim8Fury
    Those were pretty much my thoughts. I already own a 47" rear proj TV which doesn't look good with my mythTV box plugged in. I looked at hi-res plasma and to get something decent at a good size was pretty much the same price. As soon as its on a stand in the large hole left by the panasonic I'll get some pics up. I can't wait to get this thing up and running.
    edit:: yes it has seperate media box with DVB-T and a pcmcia slot apparently
  20. dickie
    dickie
    Nov 5, 2004
    61
    +12
  21. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    :clap: Excellent mate look forward to your experiences........
  22. danvitale
    danvitale
    Nov 18, 2004
    2,340
    63
    By The Sea
    +114
    Ultim8Fury, cant wait to hear what you think about it! If it works as well as it looks youre on for a winner!! :)
