SHARP Aquos 32P50E - Toshiba SD63HK
Discussion in 'LCD & LED LCD TVs' started by unknownuser, Sep 12, 2005.
  1. unknownuser
    unknownuser
    Sep 12, 2005
    13
    Hi - I have just bought a lovely Sharp Aquos LCD and Toshiba SD63HK, without realising the prog scan does not work for PAL on the Toshiba Home Cienema all in one.
    What a load of...
    Can someone please advise where to go for a software upgrade or similar in order to change this - or even if it is possible
    Thanks in advance for your help (the Sharp TV is the nuts btw)
