Sharp Aquos 26GA4E HDTV Question?
Discussion in 'LCD & LED LCD TVs' started by dj_ooms, Dec 23, 2004.
  1. dj_ooms
    dj_ooms
    Nov 28, 2004
    161
    +23
    I have just received my XBOX HD AV Box. Games look amazing at 720p. I have a question though. When I enabled the HD outputs on the settings screen, there was an option for 1080i. Does the Sharp 26GA4E support 1080i through scaling or should I leave this option off? Just asking as I can't seem to find any info on it in the manual.
  2. jgrg
    jgrg
    Oct 19, 2004
    547
    28
    Cambridge
    +33
    Yes, the screen will support 1080i input, but you're probably better off using 720p.
    To do 720p the screen has to scale it up a fraction, but to do 1080i it has to de-interlace and downscale it too.
    If you experiment you'll probably find that 720p does look better.
    James
  3. dj_ooms
    dj_ooms
    Nov 28, 2004
    161
    +23
    Thanks for the response. I just figured it out. Was mucking about with settings in XBMC and found an option for screen format. 720p looked a lot crisper than 1080i, so have left on that setting. Is it worth enabling 1080i in the XBOX settings or should I leave it disabled?
