Sharp 42xD1e-A - 1080p uncertainty
C
craigie
I have a Sharp 42xD1e-A LCD TV and have it connected HDMI to HDMI (cheap lead from Sainsburys) to a Samsung 1080p7 upscaling DVD player.
Picture and sound seem great.
How do i know that i am watching in 1080p and not 1080i (or less)?
You can set the resolution with the DVD player using the "HDMI sel" button on the remote. I toggle this until it says 1080P. If you hit the info button on the television remote, it displays at the top of the screen "DVDP" and then "1920 x 1080" and also 50HZ (or 60HZ i can't remember)
How can i be certain i am viewing at 1080p
i often hear that cheaper HDMI cables won't display a 1080p signal
How could you possibly tell that it is not displaying a 1080p signal?
How can i check?
thanks for any info.
Craig
hefestobis
If the sharp only displays 1920x1080 50hz, it's progressive. When it's "interlaced" it will show an "i": 1920x1080i
mansell
How can i check?
Craig
I have the Samsung player, if you go into the picture settings you can manually set the output to whatever you like, 720p,1080i,1080p etc
so if you set it to output 1080p then it will only output that i guess.
C
craigie
Hi there
I tried this on my Samsung, but it seems to reset back to 480p when i switch the unit on and off. What firmware version do you have? How do i find out which firmware version i have? What setting do you have for Video output under the menu - set up - display setting?
thanks
mansell
Hi there
thanks
I will have to check when I get home, you are talking about the Samsung and not your Sharp arn't you?
I only ask because I don't have the same TV as you, I have the Sony D3000.
badbob
It's the same for both sets (I had both) if it's interlaced it has "i" progressive doesn't have a "p" just the rez. ie 1920x1080
C
craigie
I am talking about the Samsung and not the Sharp. How do you check the firmware version so i can check also.
Check and see if the HDMI is still set to manual 1080p when you switch the unit on and off.
hefestobis
uncertainty, I don't think so......
As we have already explained the Sharp shows exactly the resolution it is receiving via HDMI.
