sharp 32ga4e vs tosh 32wl48
Discussion in 'LCD & LED LCD TVs Forum' started by loorenzo, Nov 22, 2004.
Tags:
  1. loorenzo
    loorenzo
    hi
    looking to buy one of those
    response time?(picture quality)
    pc input?
    and all
    is hdmi realy needed
    i will use this unit with my p
    could you help me to decide
    thanks
  2. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,109
    UK
    +369
    right now I would take DVI connection over HDMI, the tosh is said to have a 12ms response time where the sharp has a 16ms, both are good enough.
    The sharp has a better contrast and has better compatability with PC's also its lighter and the speakers can be removed and has more TV gimmicks like PIP AND PAP
  3. JonStatt
    JonStatt
    Nov 18, 2004
    3,352
    103
    +445
    I thought the Sharp only has PAP, not PIP
  4. loorenzo
    loorenzo
    thanks for fast answer
    found at flatdeal for 1299
    any better prices?
    ta
  5. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,109
    UK
    +369
    lol just ordered from Flatdeal loorenzo
  6. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,109
    UK
    +369
    sorry u may be right, it was PAP and PAT I seen
  7. loorenzo
    loorenzo
    ok
    is it Wall mounting fixation points (VESA Standard)
    because i found a good bracket at argos p634 for a 50
  8. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    As far as I'm aware, it is VESA standard at 200mm. Take a look on the Sharp.co.uk website and download the PDF.
    Richie.
  9. loorenzo
    loorenzo
    resolution matter
    the lcd is 1366x768
    my ati 9800 pro grap card propose 1280x768
    does it mean ,i will get black bordure
    ta
  10. scooby do
    scooby do
    Dec 11, 2002
    1,999
    48
    +85
    Loorenzo just use powestrip to unlock the hidden resolutions. You can get 1360x760 so that is ok.No black bars
  11. Judders
    Judders
    Oct 31, 2004
    154
    16
    Basingstoke
    I can confirm the Sharp is VESA 200mm standard. I put mine on the wall recently. I used one of these brackets Veda Z847
  12. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,109
    UK
    +369
    and so will I :D
  13. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,109
    UK
    +369
    The word on the street is the sharps are in such demand, sharp just cant cope
  14. loorenzo
    loorenzo
    thanks
    i will try powerstrip
    what about sound?
    if i add 5.1 home theatre system on my pc,can i still keep the speakers from the sharp or not
    thanks again
  15. scooby do
    scooby do
    Dec 11, 2002
    1,999
    48
    +85
    The Sharps speakers can be used a centre so could be ideal
  16. loorenzo
    loorenzo
    hi scooby do
    could you tell more about how to setup the speakers for the sharp +5.1 please
    ta
  17. scooby do
    scooby do
    Dec 11, 2002
    1,999
    48
    +85
    Loorenzo I do not have the manual to hand but I am sure I have read that the detachable speakers can be used as your centre speaker in a 5.1 set up. All you do is wire your centre output from your amp into sudio in on the sharp and then select from the audio options on the sharp use internal speakers as centre or something along them lines. My Sony KP44 PS2 does this as well and is quite effective. Mine is still boxed awaiting me to install but I have installed my Father in Laws and this is all done from memory so dont base your purchase on this in case I am wrong. Give Sharp a call for clarification they are helpful on the phone.
  18. rnsdm001
    rnsdm001
    SCOOBY DO
    Hi - we were going to buy tosh 32wl48..... think were now opting for sharp 32ga4e
    Do you know the weight of the sharp model?
    many thanks
  19. scooby do
    scooby do
    Dec 11, 2002
    1,999
    48
    +85
    as per the side of the box the weight is 31kg this includes the speakers and all the packaging. I would imagine the TV itself is approx. 24kg as the speakers are quite weighty.
  20. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,109
    UK
    +369
    sharp screen = 16.9kg
    +speakers = 20kg
    +stand = 24kg
  21. scooby do
    scooby do
    Dec 11, 2002
    1,999
    48
    +85
    Not bad guess
  22. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,109
    UK
    +369
    actual I think its on the site :D
