Sharp 30HV4E Question...
Discussion in 'LCD & LED LCD TVs Forum' started by PhilipH, Oct 17, 2004.
Tags:
  1. PhilipH
    PhilipH
    Oct 20, 2000
    167
    16
    Salisbury
    Well, a couple of questions really...
    1) Anyone know how long the umbilical is between the tuner box and display?
    2) Is it possible to get longer umbilicals if needed? (One of the two looks like a simple DVI cable but the other looks a custom made job.)
    3) Can the display be used with a DVI feed from a PC without the tuner box?
    4) Anyone got the serial protocols for this set?
    Phil
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Longer leads are available you can bypass tuner for PC use but need lots and lots of playing to get it to work....
