Sharp 30" AV Box
Discussion in 'Plasma TVs' started by pigpills, Feb 5, 2003.
  1. pigpills
    pigpills
    Hi, new to the forums, first post.
    Just bought a 2nd hand Sharp 30" LCD, but it comes with no av box (but at least with the remote). I know that there's a DVI connection on the display itself, my question is:
    a) Is it possible to get hold of the AV centre box?
    b) Since it has a DVI input (to which I'll be feeding a PC signal), are there consumer-type DVI scalers? Something like a cheesebox from Scancom, only not 15pin RGB but DVI?
    c) Anyone have general experiences with Sharp LCD's? Care to share any tips/thoughts?
    Thanks!
    pp.
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    High Wycombe, Bucks, UK
    +59
    Does it also have a second mini-DVI looking input next to the DVI?
    If it does it will probably need the media box to work.
    I would expect you could get these from Sharp, or Pioneer if it's the box I'm thinking of.
