Sharp 26GA5E vs 26P50E
Discussion in 'LCD & LED LCD TVs Forum' started by roddersmg, Aug 10, 2005.
Tags:
  1. roddersmg
    roddersmg
    Help needed, can't decide between these two, seem very similar other than the higher resolution of the A5E and the lower price. My main viewing is off-air via freeview by scart. No Sky, by the time the Beeb are broadcasting HD will have changed the set anyway. Will the P50E with it's PAL line for line scanning have better PQ? Anyone seen a set on demo yet? Many thanks.
  2. pjskel
    pjskel
    Oct 12, 2004
    2,676
    83
    UK
    +122
    If it were me, I'd probably wait a short while longer until the new GA6 comes out before making a move. See if the saving on an old stock GA5 is enough to warrant going for it.
    Irrespective of what timeframe you think the BBC will do HD OTA, I'd still sie with the 6 since Shar have probably tweaked the 5 enough to create the 6 and the difference would be noticable enough.
    Like I said, give it 'til the end of the this month or next and see how the differences stack up then.
  3. jobseeker
    jobseeker
    Aug 24, 2004
    592
    +85
    When my 37" P50 turns up (which will be when TV and Video Direct get them)I'll let you know
