Sharp 26GA3E
Discussion in 'LCD & LED LCD TVs Forum' started by motr, Mar 2, 2005.
Tags:
  1. motr
    motr
    Feb 11, 2005
    317
    +8
    Right, after much reading and searching, I have finally purchased a Sharp 26GA3E.
    Can anyone point me in the right direction where I can get decent-ish cables for under a tenner ie component to connect dvd to tv, scart for sky to tv and a decent cable to link my video camera to the dvd recorder (S-video).
    Also, what is the main difference between RGB & normal Scart?
    Wayne
  2. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    TVCables.co.uk
    RGB Scart only passes an RGB signal (When RGB is selected) since the Scart is on;y wired for RGB. Other Scarts are Fully Wired and can carry RGB, S-Video, Composite and Audio signals. The though being that the more wire the bigger the chance of interference.
    Richie.
  3. motr
    motr
    Feb 11, 2005
    317
    +8
    Thanks for that. Component cables, they only deliver picture, correct? What cable would I need to carry the sound?
  4. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    You will need a standard Phono cable (2 cables, one for left one for right)
    Richie.
  5. motr
    motr
    Feb 11, 2005
    317
    +8
    Richie, what about coaxial cables to transfer digital audio signals from the dvd?
    Will it make much difference?
