Sharp 26ga3 + Minimac
Discussion in 'LCD & LED LCD TVs' started by alscds, Mar 26, 2005.
  1. alscds
    alscds
    does anyone have any idea what the best resoloution is for running these 2 together . everytime we try to increase the resoloution we loose the picture we had it set up via dvi using av 4 digital pc input . any help please its driving us nuts :suicide:
  2. cwick
    cwick
    Feb 4, 2002
    2,207
    Reading
    +95
    Have you tried the panels native resolution (1366x768 isn't it) ? If that resolution isn't available in the Macs display perferences, use DisplayConfigX to add it.
    If that doesn't work, try using DisplayConfigX to add a standard HDTV resolution, e.g. 720p.
    Cheers, Carl.
