Sharing a RGB cable
Discussion in 'Cables & Switches' started by graeme04, Sep 5, 2004.
  1. graeme04
    graeme04
    Jun 8, 2004
    +16
    I am a little lost in the world of cables, I have looked around but can't seem to find what I am looking for, even if it exists.
    I have Sky+ and it is connected to my TV using scart, no problems at all. Now I wish to purchase a DVD recorder, it supports RGB and has a loop though feature, so I could then connect Sky+ to the DVD recorder and then connect that to the TV - so I can record in RGB and also watch Sky normally on the TV.
    But, to use the loop though you have to press a button to active it each time, this isn't a problem for me, but for everyone else in the house they won't like that.
    So I am wondering if there is a way of sharing a scart cable - so basically I am looking for a scart cable I can connect to Sky+ and that then can be connected to both my TV and DVD Recorder at the same time, so in other words I am sharing the signal.
    Thank you in advance :)
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    erm not great idea for quality and having both on screws signal and picture completely
  3. r4nd0m
    r4nd0m
    A auto RGB switcher would seem the best bet (theres a range called Trilogy), you could send the SKY+ TV out to 1 input and the DVDR's TV out to another, then connect the VCR out from the SKY+ to the record input of the DVDR thus allowing the high quality RGB signal to go to the TV whilst sending a normal video signal to the recorder.
    r4nd0m
    hope this helps
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,047
    The Borders
    +3,166
    graeme04
    If the TV has an S-Video Input why not use that as your SKY+ 'family' input - and keep RGB via the DVR for 'big daddy'.
    Best regards
    Joe
