Shallow (?) AV receivers?
Discussion in 'AV Receivers & Amplifiers' started by Zigster, Feb 11, 2005.
  1. Zigster
    Zigster
    Jan 5, 2005
    108
    16
    I'd pretty much decided on a Yamaha RXV-650 when I did one of those vital checks: will it fit the furniture? Unfortunately, the answer is no! :(
    Our TV sits on top of an old, solid wooden cabinet. The front folds down with quite a big space inside - home at the moment to DVD player, VCR and Freeview box. The space is wide and tall, but I hadn't realised its lack of depth until now (approx 420mm). This wouldn't be a problem if it had an open back but the back is wooden (with a couple of large holes drilled in it for cables to come in and out).
    Most AV receivers seem to come in at around 420mm deep so just won't fit. The Pioneer VSX-C502 seems a bit less deep at 383mm but this still doesn't allow enough room for cabling at the back. The shallowest one I've found so far is the Yamaha RXV-350 which is 315mm deep but this is a little cheaper than I'd intended on going.
    Does anyone have any other suggestions for AV amps/receivers around the same sort of depth? If not, RXV-350 it is.
    PS. Before anyone suggests the obvious, replacement of this cabinet with something that would make setting-up AV equipment is non-negotiable with SWMBO - she feels she is giving a lot of ground by agreeing to more speakers. Replacement of SWMBO is also not an option - even Homer would pick Marge over the TV.
  2. Astaroth
    Astaroth
    Jun 22, 2004
    2,283
    63
    London
    +117
    hmm... not convinced that Homer would always pick Marge over the TV. Guess the 2nd obvious option of cutting a REALLY big hole in the back of the cabinate is also out of the question.
    I think you will have difficulty in finding one with such a low depth as width & depth tend to be fairly standard for fitting in with AV racks and just the height varying - even the Cyrus AV8 is 360mm deep and they are one of the smallest I have seen
  3. Zigster
    Zigster
    Jan 5, 2005
    108
    16
    "A hole?" I can just imagine my wife saying that in her best Lady Bracknell "A handbag?" voice.
    Still, you may be right. I've found a couple more options for AV receivers (a slightly older thread suggested the Nad T743) but cutting a big hole would really widen up the field (or narrow it down to the Yammy). Maybe a big bunch of flowers on Monday would help with the persuasion.
  4. the mechanic
    the mechanic
    Nov 30, 2003
    1,193
    Wrexham,North Wales
    +52
    Zigster,
    The best solution would be to wait till "ER INDOORS" is out, get the saw and do a bit of wood butchery so she need not know. :D
    I did a similar thing but with me I swapped a pair of tannoy M3's with some mission 773e's, and my missus did'nt even notice (even tho' the tannoys were cherry and the missions were black). :laugh:
    I should'nt think you would have any probs unless your missus has eyes like a s**thouse rat. :thumbsdow
    TTFN,
    Graham.
  5. lemke
    lemke
  6. David_of_Surrey
    David_of_Surrey
    Oct 13, 2004
    200
    +6
    Yes had to cut the back out of my £900 Yew AV cabinet (no worries was a joiner once), when done it is an advantage as all the connections are dead easy to get at (no reaching into ablack hole to sort connections) if you are using a jigsaw make sure you score any cuts accross the grain with a knife before cutting to prevent splitting.
    Dont make the hole too much bigger then necessary otherwise you might be able to see around the amp to the cable mess behind when you are using
    Dave
  7. chedmaster
    chedmaster
    Jan 29, 2005
    2,654
    68
    +28
    My Sony STR-DE697 is a mere 300 mm with the volume control on the front, quite tall though
  8. Magnet & Steel
    Magnet & Steel
    Jan 14, 2005
    108
    16
    im confused as to how people part with cash for an amp without measurng up first.
    anyway! my yammy is 36cm deep without the cables. seeing as this is a pointlless thread as far as amps go, i reckon that you should just cut the back off the cabinet..with a jigsaw and claw hammer :laugh:
    or better yet, buy a decent cabinet that will support it all :)
  9. Zigster
    Zigster
    Jan 5, 2005
    108
    16
    I reckon I can just about fit the Pioneer VSX-C502 so I'm buying that one (Arena on TCR are doing me a decent deal along with the rest of the kit I want).
    Dave - Just in case it doesn't quite fit, thanks for the tip about making the hole neater - Last time I drilled a hole there was some splitting.
