Shakti Stones and Mpingo Discs
Discussion in 'AV Receivers & Amplifiers' started by spear54, Jun 26, 2002.
  1. spear54
    spear54
    Has anyone here use Shakti Stones or Mpingo discs? If so, do you have any comments as to how well they work?
  2. garmtz
    garmtz
    Mar 27, 2002
    305
    Netherlands
    These are all very "voodoo" to me. I think they can make a difference, but I think their effect will only be really noticeable in very well-balanced ultra-high-end systems. If this is not your situation, your money might be better spent elsewhere...
    You could also try normal bricks or cones or something else cheap to see if it makes a difference.
