Shaking Picture
Discussion in 'Plasma TVs Forum' started by jxs97s, Sep 21, 2005.
  1. jxs97s
    jxs97s
    I use Homechoice and recently purchased a Pioneer PDP-435FDE plasma screen. Sometimes when I turn the system on, the Homechoice picture shakes, although the Pioneer on-screen menus work normally.
    As I got the Homechoice box and Pioneer plasma at the same time, I'm not sure which device is causing this.
    Has anyone here come across this problem? Does anyone know what caused the shaking picture and / or what I can do about it?
    FYI, this only seems to be tempromental so it's not something I can replicate to figure out what is causing it.
    Thanks, James
  2. Jim_Fear
    Jim_Fear
    May 17, 2005
    1,799
    Caterham
    +59
    Signal interference perhaps? Do you have another source you can test the plasma with? I'd give that a try for a bit just to rule out the plasma, check all your leads too.
