Shadows at side of television screen
Discussion in 'TVs' started by watchmaker, Aug 31, 2003.
  1. watchmaker
    watchmaker
    Aug 22, 2003
    168
    +15
    My television set has shadows at the side of the screen. It is a JVC AV32WFT1.
    These are roughly where the vertical black bars would be if you were watching a 4:3 broadcast on a widescreen TV.
    The shadows are there on all inputs (DVD, STB etc.).
    It is most noticable on programs where most of the screen is the same light colour - for example a lot of snow or pale blue skies.
    I've tried degaussing the TV (unplugging it for a while and then plugging it back in) but this didn't have any effect.
    Does anyone have any ideas what this is and how I can fix it?
  2. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    Sounds similar to a common Philips problem! Check the sticky at the top to read about the Philips TVs, didn't realise that JVCs suffer too.
  3. Raven Storm
    Raven Storm
    my 36" toshiba picture frame is exactly the same.very annoying it is too.
  4. watchmaker
    watchmaker
    Aug 22, 2003
    168
    +15
    Sorry if I confused you but it wasn't actual "shadows" on the television but dark patches on the side of the screen.
    Anyway, I left it in to get fixed and they tried replacing the capacitor on it but that didn't fix it. Now they're going to replace the whole tube.
    Makes me glad I bought that insurance for it now!
