Sexy Wall Mounts !
Discussion in 'Home Cinema Speakers' started by cigano, Feb 14, 2005.
  1. cigano
    cigano
    Feb 7, 2005
    5
    London
    Help needed.....
    She who should be obeyed wants my nice new Bookshelf speakers (wharfedale Diamonds 9.1) off the furniture and "out of the way" Speaker stands are not an option either :(
    So hanging them on the wall, or alternativley customising some shelving seem to be my best options.
    A Question how important is the height, could I hang theses high and angle them down a little without bouncing the sound off the floor (laminate) ?
    Can anyone reccomend some nice unobtrusive brackets / mounts that would support these speakers. :lease:
    I recall a post some time back where one guy reccomended wrapping his sats in ChickenWire and hanging them off the ceiling, for an economical solution, however thats a bit too cutting edge for me :devil: :devil: :devil:
  2. Prometheus
    Prometheus
    Jan 6, 2005
    190
    Avalon
    If you come across something really special, I'd like to know too. There seems to be a real lack of choice for wall mount speakers. You can check out the old favourites that are fairly common to find, they may have a design that suits :
    http://www.avf.co.uk/prod_list.php?cat=HF
    Best of luck, I'll let you know if I come across something better. :)
  3. emtee
    emtee
    How about B&W LM1's.
    I was using them as wall mounts and they were great. I changed them to QCompacts to match my fronts. Otherwise I would have kept them. Wall mounting is a snap and the look is fresh.
  4. Douzeper
    Douzeper
    Aug 22, 2004
    190
    16
    Antrim, Northern Ireland
    Just put your foot down man, time for some mens rights :D
