Sevenoaks Brighton Tag Price Reductions
Discussion in 'TAG McLaren Audio Owners' Forum' started by Simonsound, Apr 16, 2005.
  1. Simonsound
    Simonsound
    Just popped into Sevenoaks Brighton this morning for a set of Chord interconnects and noticed they have just reduced the pricing on their last few AV32R's. :thumbsup:
    So for those of you who have not yet picked up a DP, then:-
    AV32R DP 5:1 £1999.95
    AV32R SP 7:1 £999.95
    They had a few DP 7:1's as well left! :D
    I went for Chord Cameleon interconnects between processor and power amp - sounds fab, was this a good choice? :)
  2. audionutter
    audionutter
    Jul 11, 2004
    122
    Interesting news there, what is the price for the DP 7.1?
  3. Simonsound
    Simonsound
    The DP 7:1's were going for £2999.95 some of them had DAB modules as well :D
  4. chrisstu
    chrisstu
    Feb 24, 2005
    50
    That's interesting because I was told that they were only selling 5.1 DPs and the 7.1 upgrade was only available through IAG directly. I what is being said in this forum is true, I am a tad annoyed!
  5. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,026
    +1,135
    I think the 5.1 DP has the DAB module fitted as well
  6. edward
    edward
    Apr 2, 2003
    870
    32
    Reading
    +29
    No cheap new DVD32FLRs in Black about I suppose?
  7. caleb
    caleb
    Sep 30, 2003
    368
    Cape Town (Ex Holmfirth Yorkshire)
    +3
    Jujst took the plunge and bought the last black DP in black from S/O.
    Not the same shop (bristol) but they gave me the Bristol price anyway.
    TMREQ - here I come (I'll have to fly to U.K. to collect it so any of you guys know which week Summer is this year?
  8. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    It was last week... :rotfl:
  9. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    Put your hand in your wallet mate before its too late, CD replay it a large jump up from your Toshiba.... Of course there is always the dark side (HTPC!)
  10. edward
    edward
    Apr 2, 2003
    870
    32
    Reading
    +29
    Agreed. I still have plans for HTPC but right now the missus is talking about the need for a second dvd player for the kids. The Tosh would do the job if I could replace it at a price she thought (with a bit of selling) was reasonable - and when someone says "Very affordable black DVD32FLR" the little mental cogs start engaging in a special way.
    I need to sieze the moment and wring what I can from it.
  11. caleb
    caleb
    Sep 30, 2003
    368
    +3
    BLAST - just my luck!! :suicide:
  12. edward
    edward
    Apr 2, 2003
    870
    32
    Reading
    +29
    Ha! Found a black FLR with plenty of warranty (FWIW with IAG) but it has a PSM module that I don’t need because I have one in my AV192R.
    How much extra should I expect to pay for the PSM? Would I be able to unload it for that much? How much should I expect to pay for such an FLR anyway?
  13. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    use the PSM in the AV192R...... The PSM in the FLR is lagely redundant, and isn't very swappable into a non PSM unit without a bit of work but has to be easier than putting one in a DVD32R....... Steve may know just how possible it is and therefore how easy it would be to sell on.....
    As it stands I suppose the FLR is worth about £1000?
  14. edward
    edward
    Apr 2, 2003
    870
    32
    Reading
    +29
    Thanks Graham,
    Presumably I can bypass the PSM in it without pulling the thing out. Since earlier, I have seem this module going for £300. Not sure the seller is going to want to ignore this.
    Also, having not seen it in action under test, I'm also wondering whether I lose much by not having DVI.
    If anyone has expereince here, I'm keen to hear.
  15. Spen69
    Spen69
    Drop me a line - I collected my non-psm unit a week ago from Lintone and would be interested in a swap with a psm equiped unit. It is awesome, so the psm must be even better :thumbsup:
    Cheers - Spencer
  16. Stevesky
    Stevesky
    May 13, 2004
    454
    +13
    Hi Edward,
    Transfering a PSM is not the easiest task for those without a electronics background, I wouldn't recommend it. Also once transfered the ADC should really be recalibrated to ensure the unit is up to factory spec - resell value is low as it's really a factory fit (or a dealer with a proper service dept.).
    If you use the phono outs of the DVD32FLR then you get the interlaced out (pre-psm), so feed that to RGB1 of your AV192R and you will get the same result + you get AV192R OSD.
  17. Raphie
    Raphie
    Mar 9, 2005
    46
    I have the DVD32FLR without PSM as wel i am hoping on IAG to offer the (nonexistent :rolleyes: ) PSM HDMI board as retrofit option. I currently have a Pioneer 868 as well and the only reason he's still there is because of the HDMI and 1080i scaler built in. So any gossip about a HDMI 1080i scaler retrofit for the FLR?
  18. edward
    edward
    Apr 2, 2003
    870
    32
    Reading
    +29
    Thanks for that Steve.
    If I get this particular unit, Spencer might sold my problem nicely. His unit sound to be about the same age, so...
    Are you recommending composite video over s-video output from the standard DVD32FLR? Would I see the difference?
    Hear you were in the area on Sunday. I'd known I'd have invited you and Steve out when I put the wind through Mike's hair between here and the Stag and Huntsman.
  19. simon40
    simon40
    May 30, 2003
    192
    Dorset
    +4
    Edward,
    I assume the o/p connections on the FLR are the same as my 32R, therefore you will have component out via BNC connectors.
    Simon
  20. Stevesky
    Stevesky
    May 13, 2004
    454
    +13
    Nope, when I say phonos I mean the 3 phonos carrying the interlaced YPbPr component signal
    Not when a PSM192R is installed. the three BNC's will carry the progressive output from the PSM, the three phonos will carry the interlaced component output.
  21. sijones
    sijones
    Nov 5, 2001
    632
    Reading
    +34
    Hi Steve,
    Would it be easy to modify the DVD32FLR (internally) so that so that the progressive signal is on the phonos and the interlaced signal is on the BNCs?
    Regards,
    Steve
  22. Stevesky
    Stevesky
    May 13, 2004
    454
    +13
    Hi Steve,
    It's quite feasible, but making gear non-standard is not a good idea expecially if people then expect IAG to fix them if it went wrong!
  23. sijones
    sijones
    Nov 5, 2001
    632
    Reading
    +34
    Do the phonos only ever carry the DVD output even if you route an s-video signal through the player?
    Regards,
    Steve
  24. Stevesky
    Stevesky
    May 13, 2004
    454
    +13
    Hi Steve,
    The interlaced component output on phonos only carries the DVD player output, it does not cross convert from the PSM external s-video or composite inputs.
  25. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    Yep only the PSM output does that......
  26. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    I would not bet on ever seeing an HDMI output board option for the DVD32R/FLR, There is really no point at all...... A decent off board scaler is the better bet as it has far more uses.... Of course should we see an all new AudioLab DVD player I'll bet it will come with all the toys...... I doubt it will be this year though......
  27. liam_b
    liam_b
    Apr 24, 2002
    390
    28
    Wilds of north Leicestershire
    +25
    theres no reason for any Pioneer clone not to have all toys, even Lexicon could manage that :devil:
  28. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    Right, lets put a few thoughts into the melting pot.
    I haven't seen a Pioneer (or for that matter any domestic DVD player) via HDMI that has a better image quality than a DVD32R via component, some are close, some may even be the same but the clincher has always been the superior CD replay ability of the DVD32R. The PSM in the DVD32R is still perfectly acceptable as a deinterlacer (testemement to the original design maybe!), however the interlaced component output on the DVD32R is non too shabby either and this output fed into an off board scaler (which would also deinterlace) produces the best results normally. Anyone selling a PSM module for a DVD32R should be aware that it requires a fair bit of TAG knowledge to fit it into another DVD32R. it is not a normal DIY thing. Therefore its value as a standalone product is not that high in fact it isn't worth much at all unless some technical type is fitting it (and that is where the cost comes in), you can buy DVD players with the same PSM chipset already built in for very little money.....
    I have a PSM equipped DVD32R and never use the DVI output from it these days as the picture is so much better from the interlaced component output into a scaler (which also has a deinterlacer chipset the same as the PSM built into it...), I've tried feeding the DVI DVD32R output into the scaler and it isn't as good for some reason.
    A DVD32R/FLR is still a very good video and audo player and is worth all (and more) of the £1k or so people are picking them up for these days, you will not find a better player for the money assuming the rest of the gear can take advantage of it. If you already own a scaler that has built in deinterlacing then I'd suggest you feed it the interlaced output from the DVD32R, sit back and enjoy.
    If you have no off board scaling equipment then the PSM has merit as it will be as good as many display inbuilt devices, but the current crop of video processing chipsets being built into the new ranges of displays are now a match or even maybe better than the PSM (remember it is around 4 years old now!!!) and of course it isn't optional when built into these displays so you get it if you like it or not so you may as well use it....... Simply buying a PSM to get a DVI output on your DVD32R/FLR assuming that will give the best picture doesn't hold up, buying a DVD32R/FLR for reference quality CD playback and an excellent interlaced component output does....
    Flame proof suit now being worn.....
  29. derekn
    derekn
    Jun 8, 2004
    715
    28
    Bristol
    +37
    Absolutely spot on Graham.
    Derek
  30. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    It didn't make it a great player though.....
