Setup Query
Discussion in 'Cables & Switches' started by TheCat, Sep 13, 2004.
  1. TheCat
    TheCat
    Sep 3, 2003
    91
    9
    Peterborough
    I'm running a fairly budget system with a Denon amp.
    The amp has two channels with A running the 5.1 system incorporating fairly small yamaha speakers and B being the stereo only channel.
    I intend buying new stereo speakers, but am I better leaving the Yamahas on the A with the new speakers on the B. (At the moment my stereo speakers are not either side of the TV) or putting the front Yamahas on the B and running the better speakers as the front 5.1 part?
    When I rearrange the room shortly, the B speakers will be either side of the TV.
    Or, if I play both A & B channels will it make no difference?
    Thanks for any advice.
