Setup problems with Free2view
Discussion in 'Satellite TV, Sky TV & FreeSat' started by rayhill1, Oct 30, 2004.
  1. rayhill1
    rayhill1
    Oct 29, 2004
    2
    Inverness
    I'm moving to a location in the Scottish Highlands where BBC Freeview is not available and do not particularly want Sky - the standard five channels I currently get via terrestial will do fine. Trouble is the aerial reception is not good and the house does have a satellite dish so I've acquired a panasonic Sky digibox from a friend and a Sky viewing card, yellow house and activated, via ebay. I hit the following problems.
    1. On occasions I just get a message saying there is no satellite signal. If Idisconnect and recycle I may then get reception again
    2. But then, at present I can only get BBC Emidlands on 101, Chan4 0n 104 and Chan 5 on 105. BBC2 England and ITV do not at present appear although a month ago I did get them for a couple of days.
    3. If I go to say 941 for BBC1 Scotalnd again the no satellite signal message appears.
    It does not appear to be a dish problem - all the time there is a good 18 volts
    at the masthead.
    Any suggestions woul be very gratefully received - or do I just give in and get Sky on a minimum contract for a year
    cheers
    ray hill
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    The dish could be slightly out of alignment, the LNB could be faulty or need adjusting and the cable could be water damaged not to mention a dodgy tuner in the digibox.
    The FTV card was registered for a different region and the FTV channels take time to be recognised that's assuming you have a good lock on the default transponder in the first place.
    SKY's "freesat" offer is out now, £150 for a brand new installation with FTV smartcard and full warranty with no monthly subscription. Probably a better option then spending money getting your current hardware up and running. Assuming you have never had a subsidised SKY install before you can take advantage of their offers, get free hardware but take out a 12 month contract but packages can be adjusted within the 12 months to the minimum value.
  3. tomleeeee
    tomleeeee
    Where's the info about this 'Free Sky' £150 offer? I've checked sky.com but can't find it anywhere..!
  4. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    They have never been to keen to advertise products that don't come with a subscription:)
    I've seen this website , might be genuine, either way just contact SKY directly they will be able to give you any further details.
