setup on a yamaha dsp-ax620
Discussion in 'AV Receivers & Amplifiers' started by mkendall, Nov 18, 2001.
Tags:
  1. mkendall
    mkendall
    I can't get the OSD working on my amp
    I've tried connecting s-video out of the monitor out to the front of my toshiba and get the message on the front of the amp DISPLAY OFF
    I've tried with video cable but same message
    Its turned on to auto in the setup menu but no joy!
    any help please
    Mike
  2. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    Repeatedly press the center button in the scrolling pad. I can't remember what the title of the function is, but it selects between full, limited and no display through video out.
    At least in theory. I've never used it myself, so I make no promises.
  3. Spencem
    Spencem
    Oct 15, 2001
    197
    Northampton
    +9
    Have you set the front input to S Video, I had the same problem until I realised that AV3 wasn't set right. My 620 had the OSD turned out out of the box, I've seen in the manual that you can turn it off, but I've never tried.
    Good Luck
