Setup niggles on 1st proper system
Discussion in 'Blu-ray & DVD Players & Recorders' started by Trogster, Jan 2, 2005.
  1. Trogster
    Trogster
    New system Panasonic tx32pd50
    Pace Sky box
    Panasonic Dmre55
    Aeriel booster/splitter to send tv and sky on loop round home
    I gather from these forums that the best setup is sky>dmr>tv in a loop as only one of the sky scarts is rgb which scart socket on tv do I then use or can I use the component outputs from dvd
    Secondly with my old system I could watch a video in another room by means of the rf out on the video going to the aerial booster , I cant get this to work with the dvd recorder ,does it output via this method when hooked up via scart or component as well
    getting a very sore head puzzling over it :confused:
  2. dekoded
    dekoded
    Oct 30, 2004
    893
    Blackpool
    +45
    I assume your tv has component input for prog scan, if so then if it's possible I would say that the best option would be:
    sky (rgb) > dmr (rgb) >tv (via scart for watching sky)
    and if possible also connect component output (3 x rca/phono sockets) from dmr to tv for watching dvd's. Although I don't know if it's possible/practical to have both connected at the same time.
    As for the RF I thought that this signal is normally 'passed through' and is independent of the other connections.
    :smashin:
  3. bobcar
    bobcar
    Oct 3, 2004
    708
    +21
    The E55 does output via RF. You have to have it enabled (I can't remember if it enabled by default), to do this hold the function key down until the correct menu appears.
  4. Trogster
    Trogster
    Thanks for the advice I'll give it a blast
    Tv does have component inputs and I think it can be hooked up as suggested
    as for the rf output I'll have a deeper delve thru the menus to check that
  5. Fred Smith
    Fred Smith
    Apr 23, 2004
    1,811
    Reading
    +267
  6. Trogster
    Trogster
    Thanks for all the help on rf output problem now resolved by holding down function button for 5 secs and selecting an output frequency
    The system setup I'll have to leave as is until I branch out into surround sound as component inputs don't carry audio so one of the two scarts on the dvd needs to carry the audio to av4 on telly and there doesn't appear to be an optical in on telly
