mepsipax
I have got myself into a mess with my AV setup, (as I stupidly undid everything whilst decorating) and would appreciate some help.
My setup -
TV Toshiba CRT 36zd26 with component connections and 3 scarts (i think 2 of these are RGB).
Panasonic DVD Recorder E55
Yamaha AX750 Amp
NTL Digibox with 2 scarts
Video Sender with scart attachments
1) At the moment I can only view the E55 through EXT 3 on the TV, previously it could be seen on EXT 1
2) No sound for E55 recorder through optical out (bottom port) on amp. Have cycled through all the options on the amps on screen menu, and have re-assigned outputs ie - DTV/Cable VCR Phono etc. but getting no sound, even though this wasn't unplugged.
3) Video sender will work if plugged into bottom scart of NTL box, but picture sent upstairs is in black and white.
Trouble is, I need that bottom scart of the NTL box for the E55 - i think.
These all worked previously, so obviously I have set it up wrong this time.
Advice appreciated
My setup -
Yamaha AX750 Amp
Advice appreciated
