Setup advice needed please .....
nickp8
http://www.uk-fones.com/plan.jpg
Above is the planned layout of the living / HC room.
Can anyone recommend a speaker set up that will suit the room and sound good for both when viewing the tv and using the projector.
In-ceiling speakers are an option, with a sub on the floor.
What 5.1 / 6.1 / 7.1 be best?
Thanks.
Nickp.
nickp8
:lease:
Ian J
I'm afraid that your question is much too vague. You really need to post a budget plus any other constraints that you may have.
nickp8
At the moment all I need to know is what set up would suit the room and where the speakers should be positioned.
If anyone can recommend a set up using the Canton powerbuy post that would be ideal. I like the style / price of the range.
http://www.avforums.com/forums/showthread.php?t=195561
I am not after large floor standing speakers. Speakers must be wall mounted / in-ceiling.
Thanks.
