Settings using THX disc ?
Discussion in 'Plasma TVs Forum' started by Daipac, May 3, 2005.
  1. Daipac
    Daipac
    Apr 12, 2005
    658
    +12
    What does this mean ? I have seen it mentioned that you can use a THX disc to setup your plasma, how does this work ?
  2. rimibar
    rimibar
    May 17, 2003
    428
    Cambridge
    +4
    It means that on a THX disk - Finding Nemo, any of the Star Wars DVDs etc, theere is a "THX Optomiser" usually found in either the settings or language menus of the DVDs. It helps you calibrate audio & video.
    However BEWARE these optimisers are optimisers for the DVD itself and should not be used for general setup. For the latter use DVE or AVIA set up disks (do a search and you'll find more info)
