Settings to use on LG 65UN711C0ZB to get a satellite signal through an SCR.
ALH91
Hey!
Hopefully this is a super easy answer, but I live on a new development and when buying the house the developer provided a help guide to give to your Sky installer. I'm hoping the instructions on how to install Sky will help work out how to use the TV's built in FreeSat to pick up a signal. Basically saying if you are installing:
SkyQ: Connect the box to SAT 2 Connection in the wall, then change the settings on SkyQ Box to SCR (then lists the instructions how to)
Sky+: Connect the box to both SAT 1 & SAT 2
When running an autotune on the TV on all three forms of tuning Terrestrial, Cable and Satellite it isn't picking up anything. I have tried different configurations of the cable connection. But I have a feeling there maybe some setting that need to be set before scanning such as Unicable or DiSEqC.
Any help would be massively appreciated!
Thanks,
Ash
Podcast: Anthem AVM 70 Review, EQing Your Home Cinema Sound System and More...
