Settings to test Denon AVC A11SR
Discussion in 'AV Receivers & Amplifiers' started by thestorm, Feb 28, 2002.
Tags:
  1. thestorm
    thestorm
    Jul 13, 2000
    547
    East London, UK
    +30
    Hi all
    If i want to testand calibrate the sound levels on a Denon AVC A11SR using a test DVD, what settings should I set the
    11SR to? From the remote if i selelct 5ch\7ch the sounds are mixed eg if i'm testing the centre channel, sounds
    come from the front speakers too. With pure direct and direct the sound is just stereo.
    One way in which sounds comes from specific channels is if i select THX button on the remote.
    Please can you advise me on this as I'd like to make sure I have my syatem setup properly.
    cheers,
    Shaz
  2. Jase
    Jase
    Mar 16, 2001
    10,820
    United Kingdom
    +2,697
    First use the internal test tones to balance all the channels.
    On test discs such as AVIA you´ll be using Dolby Digital to balance them all. This will affect DTS, Pro-Logic, DTS-Neo etc etc
    You can then use THX and balance them using this as well. The Denon stores THX settings independently of Dolby/DTS etc.
    Whilst they should be the same overall in practice, THX can have slightly different results.
  3. thestorm
    thestorm
    Jul 13, 2000
    547
    East London, UK
    +30
    the denon was automatically perfectly balanced, as i definted
    how far away each speaker was.
    >On test discs such as AVIA you´ll be using Dolby Digital to >balance them all. This will affect DTS, Pro-Logic, DTS-Neo etc etc
    >You can then use THX and balance them using this as well. The >Denon stores THX settings independently of Dolby/DTS etc.
    im using ultimate dvd platinum, and setting the volume knob to
    00db, so playing the dvd at 00 give me a value FAR greater than
    75db infact it goes right of the scale.
    And it's way too loud. what volume level should i have the denon
    at?
    Cya,
    Shaz
  4. Jase
    Jase
    Mar 16, 2001
    10,820
    United Kingdom
    +2,697
    The Denon does NOT automatically balance the channel levels.
    What you´re referring to is the delay times in regard to your seating distance from each speaker.
    To balance with an external disc just start the test tone and then turn down the main volume level until the sound meter reads 75db (this may equate to around -15db on your volume display). Then balance all the other channels in relation to each other.
  5. Stewart C
    Stewart C
    Agreed.
    Regards
    (Fellow 11SR Owner)
  6. johnson
    johnson
    May 12, 2001
    552
    Essex
    +6
    I'm not sure about your experiences but when I had an avc-a11,The in-built test tones were exactly the same (using spl) as ones from a dvd player/test disk.
    Regards
  7. Stewart C
    Stewart C
    I too found them to be the same as the DVD which is good. My old amp sucked and was different.
    I do not have the new THX Optimiser disc yet.
    Regards
  8. dts_boy
    dts_boy
    Nov 26, 2001
    2,669
    Manchester suburbs...
    +215
    I have a 1se and have set the levels to 75dB at my regular listening level (around -25). is not the right way to do it - at YOUR listening level? i am unsure, would like a definitive answer from an installer please!!!:confused:
  9. thestorm
    thestorm
    Jul 13, 2000
    547
    East London, UK
    +30
    Salaams dts_boy
    have a peep at this, i hope it helps :
    Audio Calibration
    Cya,
    Shaz
