Settings Lost on KV36FS76. Is This Normal?
Discussion in 'General TV Discussions Forum' started by Julia, Sep 3, 2003.
  1. Julia
    Julia
    Maybe someone can help?
    I've just got a KV36FS76 and everything seems to be OK, apart from the fact that if I change the value of the Contrast from 100 to about 50, next time I switch the TV on, the value is lost (and I have to set it up again).
    The user manual I've got is in French (still waiting for the English version that should arrive next week).
    What can I do to make sure the change of settings is saved?
    Thanks,
    Julia
  2. SimonO
    SimonO
    Nov 4, 2002
    3,293
    71
    Hertfordshire
    +64
    Make sure you make the adjustments in 'Personal' mode... I prefered 'Movie' mode as it disabled SVM, but unfortunately you cannot save your settings...
  3. Julia
    Julia
    SimonO, Thanks for your help. I wonder why they've set contrast to the Max as a default value.
    The TV seems to work OK (the only thing I've noticed was a very slight green staining in the upper left corner (I'm not sure if I could adjust that, maybe not).
    Regards,
    Julia
  4. Radiohead
    Radiohead
    Dec 24, 2001
    4,392
    Amazingstoke
    +432
    I can save the settings in Movie mode on my FQ70........is the FS76 different then?
  5. SimonO
    SimonO
    Nov 4, 2002
    3,293
    71
    Hertfordshire
    +64
    Yes it must be different... Julia, my FS76 also had slight green staining in the top corners... I think it is caused by the speakers... Not much you can do about it I'm affraid...
