Settings help for bluray player.
Discussion in 'Blu-ray & DVD Players & Recorders' started by skytra7, Feb 28, 2014.
  1. skytra7
    skytra7
    Jun 5, 2006
    161
    19
    Hi just recently bought a bluray player and I'm trying to understand the setting so that can get the best possible sound for my 2 channel speaker setup.
    My Bluray is connected to the TV via the AV reciever HDMI style.
    My Sony BDP S1100
    https://docs.sony.com/release/BDP-BX110_S1100.pdf
    DOWNMIX
    with this "Downmix" setting (Surrond OR Stereo) I've left it on surround even though I have a 2 channel setup becasue I somehow think that I will lose some of the dynamic information if I put it on Stereo...is this true? IS is better to leave it on Surround even with a 2 Channel setup. My Reviver says "2 Ch Downmix" on the front panel though...
    DTS Neo:6
    I have this setting ON by default which is Cinema. Something though tell me I should switch this off especially if it degrades the DTS-HD MA audio in any way..! Can anybody confirm?
    advance thanks for any help given
  2. mentm
    mentm
    Jun 20, 2008
    4,139
    Wiltshire
    +466
    With down mix try both, it will mean either your receiver or bluray player are doing the conversion.
    Dts neo 6 is for stereo sources and should be turned off if you only have a stereo setup.
