Settings for prog scan on th-42pw5
Discussion in 'Plasma TVs Forum' started by ted26, Sep 15, 2003.
  1. ted26
    ted26
    Apr 10, 2003
    512
    yorkshire
    +6
    Can anyone tell me if there are any special settings on my plasma to recieve progressive scan?
    And how can i check the plasma info to see if i am recieving the right signal?
  2. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    You don't need to change any settings on the plasma to receive progressive scan signal just make sure that the source is outputting prog scan signal.
    2nd part
    Originally posted by jmack
    1. Hold the volume button on the panel in while pressing the status button on the remote 3 times very fast (status button is the one under the power button).
    2. A menu appears highlight the icc menu and press select.
    It should say in the top right hand corner what signal is showing ie 525p 525i 625p 625i.
    You must have your panel on the component imput and your dvd player on at the time of doing this.
    To get out press the setup button then turn the panel off.
    Not sure if it works if you have a tuner connected though.
    Be careful in there dont go changing things.
  3. ted26
    ted26
    Apr 10, 2003
    512
    yorkshire
    +6
    Its showing 525p
    thx for help :)
  4. IanThornton
    IanThornton
    I have the same screen with tuner box. Simply pressing the Status button shows "Progressive Input" immediately under the "16:9" text.
    Ian.
  5. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
  6. ted26
    ted26
    Apr 10, 2003
    512
    yorkshire
    +6
    have we been here before :D
