Settings for Powerstrip, 9600 and AE100?
Discussion in 'Desktop & Laptop Computers Forum' started by RichardH, Aug 24, 2003.
  1. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    Just upgraded my graphics card from Radeon 7000 to a 9600, but am having probs getting it into wide480 mode. Is there another Powerstrip setting needed for this card?
  2. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    The 9600 shouldn't make any difference to the settings but have you got the latest version of powerstrip as the 9600 didn't used to be supported. It might help if not I have the wide 720 settings somewhere but I never used to like the image from them myself.
  3. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    I've tried the latest version of Powerstrip - no different.
    As soon as I apply the 480wide settings, the screen scrambles - this happens whether I'm using the PJ or a normal monitor (at first I thought it had set an incorrect refresh rate).
  4. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    These are the ones I used to use
    PowerStrip timing parameters:
    856x480=856,40,72,80,480,4,5,11,31500,342
    1280x720=1280,56,120,240,720,4,6,20,76500,342
    Only other thing I can suggest is to visit the entech forum:confused:
  5. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    Finally got a chance to fiddle. Made progress, after a lot of false starts - damn that ATI control panel. Now uninstalled it, and tried the drivers that came on the CD as well as the latest from the ATI site.
    Been so long since I've had to fiddle, I'd forgotten about setting the monitor to be a Sony 900W and all that.
    Anyway, I have the PJ kicking into 480 wide properly now, but at that resolution I'm getting a nasty display prob (see pic). This happens on a CRT monitor as well as the PJ at this setting (which is the 480 you posted John).
  6. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    ...HA! Got the little so and so. Found some alternative Powerstrip settings (good old Shockabuku's website) which did the trick.
    Phew!
  7. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    Glad you've sorted it!
  8. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    Me too - Two Towers tonight!
