Setting up wireless broadband.
Discussion in 'Networking & NAS' started by knb, Feb 8, 2009.
  1. knb
    knb
    Feb 8, 2009
    19
    Hi Everyone
    I would be very grateful for advice on this. I had assumed that all I would need would be the wireless modem (Siemens Gigaset SE587 WLAN dsl provided by Tiscali) but when I try to install the software I get a message that says Network Cable Unplugged. Reading up on setting up wireless today some sites say that I need an adapter for the USB port to pick up signals. Will this solve the issue. I am tearing my hair out trying to figure it all out! If you can help please explain it in a way that a newbie to computers will understand.
    Many thanks
    Kerry
  2. mickevh
    mickevh
    Apr 30, 2007
    7,206
    West London
    +1,722
    What are your client devices - (PS3, XBOX, laptop, MacBook, etc.)
    Presuming a laptop PC, to use wifi it needs to have a wifi network adapter. Ninety-something percent of laptops sold in the last few years have them built it, but check the spec. sheet.
  3. knb
    knb
    Feb 8, 2009
    19
    I am trying to connect two desktop pc's. Both are new within the last two years and both running windows xp (one service pack 2 and the other service pack 3). If I don't have the spec sheet is there a way of seeing if I have a wifi adapter installed?
    Kerry
  4. Abbadonuk
    Abbadonuk
    Jan 25, 2009
    41
    Birmingham
    +5
    Richt click on "My Computer" and select "Properties".
    Then go to Device Manager.
    This will display a list of installed devices, under "Network Adapters" you will probably just find your ethernet adapter meaning you need to purchase a WiFi card or USB dongle.
    It it has Ehernet and Wireless/WiFi then you just need to configure it.
  5. knb
    knb
    Feb 8, 2009
    19
    I have a Realtek RTL8168(P)/8111C(P) PCI-E Gigabit Ethernet NIC installed. Will any USB dongle work or do I need a specific one to work with Siemens Gigaset SE587 WLAN dsl? How do I figure out which type to get if I do need a specific one?
    Many thanks for your help.
    Kerry
  6. Abbadonuk
    Abbadonuk
    Jan 25, 2009
    41
    Birmingham
    +5
    Any should work but try to get a Wireless N USB adapter as it is more future proof.
  7. knb
    knb
    Feb 8, 2009
    19
    Thank you!
    Kerry
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    Or just connect a netwrok cable from router to PC
  9. beerhunter
    beerhunter
    Nov 9, 2005
    6,335
    Hampshire
    +740
    Yes you need some WiFI adapters. I would not use USB though. For desktops PCI is best. Read the many threads here as to why.
  10. knb
    knb
    Feb 8, 2009
    19
    Thanks for your input.
    I have been reading the forum posts on usb v pci card but so far have found no info on how I would figure out which brand/make/type of pci I would need. Will they fit all computers or do I need to figure out my existing system and buy a compatible one? Also are they difficult to fit and can you recommend anywhere on the net that gives reliable info on fitting them.
    Many thanks
    Kerry
  11. beerhunter
    beerhunter
    Nov 9, 2005
    6,335
    Hampshire
    +740
    I am surprised that you didn't find stuff about PCI WiFi cards.
    They are extremely easy to fit. A PCI card will fit the PCI slot of any PC.
    They will all conform to the IEEE standards 802.11b/g/n and will all have drivers for Windows XP/Vista.
    They will cost about a tenner each.
    Having said that if one or more of the PCs are in the same room as the router I would use Ethernet. (The routers and the PCs will already have that.) and you may want to read the FAQ on Homeplugs.
  12. knb
    knb
    Feb 8, 2009
    19
    Thanks Beerhunter. I have one PC in the room with a router and that will be connected via Ethernet but I want the wireless for a pc in another part of the house.
    Regards
    Kerry
