setting up toshiba 37wlt66 as pc monitor
Discussion in 'LCD & LED LCD TVs Forum' started by jojoed, Dec 30, 2006.
Tags:
  1. jojoed
    jojoed
    I bought the toshiba 37wlt66 yesterday and have been trying to work out how to set it up correctly to my pc ever since! it works fine just as a tv,but when I use it as a monitor it has two thick black lines down the sides of the page. I have tried all of the pre-set resolution settings but none of them seem to work.
    if anyone knows how to set it up I would really appreciate any suggestions!
    thx.
  2. druidvideo
    druidvideo
    Apr 22, 2005
    95
    11
    London
    +7
    The VGA input doesnt do 1:1 mapping that I am aware of. You may be better off converting your DVI out to HDMI (if you have DVI out).
    There is a big thread about the wlt66 and vga issues if you search.
